 Пол:  Стаж: 3 года 2 месяца Сообщений: 19235
JCE Editor + плагины
Версия компанента: 2.3.4.4 Версия плагинов: 2013 Год выпуска: 2013 Разработчик: www.joomlacontenteditor.net Таблетка: не требуется Требования: joomla 3 Язык: Русский В версии 2.3.4.4 внесены следующие исправления: Fixed : Remove Format button Fixed : Active Line background colour in monokai Source Code theme Fixed : Cannot drag and drop images around editor in Chrome. Added : Text filetypes to File Browser PErmitted File Extensions Fixed : Long Description browser in Image Manager shows all files, not just imagesChangelog2.3.4.3 Fixed : Strict Standards error in the JCE File Browser Quick Icon Fixed : Error when saving configuration in Joomla 1.5 Fixed : Error that could cause the Save / Cancel buttons to fail when the Editor Profile contains "hgroup" in the Format list. 2.3.4.2 Fixed : First Plugin Parameter tab item not removed when removing plugin from the editor layout. Fixed : Updates download errors Fixed : Some javascript files not minified. Fixed : Update mime types list to include various ogg formats Fixed : Vertical Align option not visible in Table dialog. Fixed : Browser spellcheck option not available in IE11 Added : Enter Key behaviour to escape block elements using ALT+Enter and ALT+Up Changed : Removed ?etag=hash and replaced with ?hash on all javascript / css requests. Added : Full set of block elements to Format elements list, removed hgroup. Added : All valid elements to Custom Styles widget divided into new HTML5 categories. Fixed : Link dialog showing Mixed Selection when only text selected. Fixed : Editor content area not resized properly when using Toggle Toolbars. Fixed : Error when switching to fullscreen if first element in the editor is a comment. Fixed : Allow generic media elements to omit embed and param tags. 2.3.4.1 Fixed : Dialogs not loading correctly when Compress CSS enabled 2.3.4 Fixed : Loading language files on some systems where parse_ini_file is not available. Changed : Editor Global Configuration is now stored in the JCE Editor Plugin paramters to prevent it being overwritten when saving Component options. Added : set etag header based on file hash on compressed files to improve browser caching. Fixed : Installtion error in Joomla 1.5 when copying index.html files Added : Style Formats widget to create custom options for the Styles list. Added : Block Formats widget for setting / ordering Format options. Added : Font Family widget for adding new fonts to the Font Family list. Changed : Replace use of &version with &etag using file hash or version hash. Fixed : Improved error display in Updates dialog. Fixed : Error when searching profiles in Joomla 1.5 Fixed : Parameter value position in Joomla 3.2 Fixed : Added dummy "&file=extension.xml" to updates url to prevent Joomla from adding "/extension.xml" Fixed : Help dialog display in standalone File Browser dialog. Changed : Return Custom Colours option to Colorpicker Changed : Move Paste As Plain Text out of drop-down menu to individual button. Changed : Disable Google Spellcheck option as the service has been discontinued by Google. Fixed : Window scrolling when a dialog is open on small screens. Fixed : Table dialog not showing correct options when editing a cell / row. Fixed : Ordered / Unordered List detection and conversion when pasting from Word. Added : Options to set JCE MediaBox default values for popup tab. Update : Codemirror to 3.1.9 Added : Option to set Source Code Editor font size. Fixed : Better handling of Geshi code. Fixed : Error messages not always translated. Fixed : Double encoding of parameter values in JCE MediaBox popup. Added : Remove Tags, Keep Tags and Remove By Regular Expression options in Clipboard / Paste parameters. Added : Option to set a class to the editor body element. Changed : Use protocol relative URL when inserting Vimeo, Youtube and GoogleMaps. Fixed : Use seamless attribute for iframes in HTML5 Doctype instead of frameborder Fixed : Element / Text selection in Link dialog where selection is a block element. Fixed : Getting / setting Youtube privacy mode when inserting Youtube video. Fixed : Resizing of editor when "Toggle Toolbars" option is used and editor is hidden in a tab. Update : TinyMCE 3.5.10 - includes various fixes for IE11 Fixed : Improve support for generic media types Fixed : Improve support for Bootstrap style icon tags. Fixed : Improve Footnotes conversion when pasting from Word. Fixed : Error when editing a JCE MediaBox popup when the rel tag contains a non-standard value. Fixed : Add video id to Youtube playlist option when loop is enabled. Fixed : Error in Weblinks and Contact items in Link Browser in Joomla 3.2 Fixed : Error inserting images when Validate HTML is No and span is set as a Prohibited Element. 2.3.3.2 Fixed : loadResultArray error when installing editor on some Joomla 3.1 sites. Fixed : Error / blank screen when uninstalling editor. Fixed : Link dialog creating popup links with href="#mce_temp_url" Fixed : Invalid Path error on drag&drop upload of images with invalid characters in the name. Fixed : Error -200 changed to "Upload error. The server returned an invalid response." Fixed : Various button names not displaying correctly. Fixed : Error when processing audio/video tags if no source tag exists. 2.3.3.1 Fixed : Dialog's don't load when Compress Javascript is enabled. 2.3.3 Changed : Style JCE Administration using Bootstrap Changed : Only save edited parameters - reduces POST data sent to server and therefore fixes issues saving on servers running the PHP suhosin extension. Changed : Use javascript to extract font-face and colours from template stylesheets to prevent recursion errors with some stylesheets. Changed : Remove Custom Colours parameter in Editor Profiles -> Editor Parameters. Custom colours should be added to the template stylesheet from where they will be extracted and displayed in the Template tab of the colour picker. Changed : File Browser "Search" now searches the entire current folder rather than just filtering the visible list. Changed : Images will now be inserted without dimensions by default, unless dimensions set are different to the original. Added : Basic LESS support for editor stylesheets. Added : Upload Image Placeholders - allows users to upload images into placeholders in content. Added : Convert local images to placeholders when pasting in content from Word etc. Added : Twitter Vine aggregator to simplify insertion of Vine videos via the Media Manager, as with Youtube, Vimeo etc. Fixed : Extra empty rows added to editor layout when saving in Firefox. Fixed : Show Loading bar when opening Profile for editing. Fixed : Add data-cfasync="false" to script tags to prevent Cloudflare Rocket Launcher processing. Fixed : Clean Word Content when pasting as plain text. Fixed : Double processing of URLs in pasted content. Fixed : Ordered list conversion when pasting from Word etc. Fixed : Allow for custom media types in object tag, eg: video/youtube Fixed : Remove html indent when toggling editor as it was removing whitespace in pre tags. Fixed : Make Cut/Copy/Paste shortcut labels platform specific, eg: CTRL+V to CMD+V on Mac Fixed : Check extension xml files are valid before processing. Fixed : Prevent multiple classnames from being removed when editing table/cell/row Fixed : Firefox bug where image is opened in a new window if dropped onto itself Fixed : Fix some issues when inserting data into the editor from external dialogs. Fixed : Table cell selection when using the right-click context menu. Fixed : Current element selection when updating the table. Fixed : Invalid html of pagebreak hr tag. Fixed : Include article language when processing Content link in Link dialog. Fixed : Update validation of wmv mimetype to include it as video/x-ms-asf Fixed : Allow links to be created on inline html tags, eg: , etc. Fixed : Cookie not stored when directory changed in File Browser. Fixed : Add allowfullscreen attribute for iframes Fixed : Error when renaming folders. Fixed : Search/Replace issues in Code View. Fixed : Fix processing of geshi code Fixed : Menu links to "secure" menu items now set as https links. Fixed : Close Rename dialog after warning when renaming files/folders in File Browser. 2.3.2.4 Added : Option to pad empty table cells with a (on by default) Added : Various work-arounds to prevent bootstrp icon code from being removed. Added : "Update All" checkbox in Updates dialog. Changed : Clipboard "Strip Class Attributes" option now a simple Yes / No option. Chaned : CODE and SAMP Format options are now applied as inline. Fixed : Search / Replace dialog not working. Fixed : Cannot create file links on some systems. Fixed : Cannot create new tables rows after merging in Safari. Fixed : Options removed when creating popup links to flv files with the Media Manager. Fixed : Some empty paragraphs not removed when pasting from Word. Fixed : "Remove Attributes" Clipboard option not working as expected. Fixed : INVALID MIMETYPE error when uploading docx files. 2.3.2.3 Fixed : Colourpicker dialog blank on some systems Fixed : Allow backslash in file paths (WAMP, IIS) Fixed : Updating FLV in Media Manager would remove some options. Fixed : Cursor jumping when inserting table, pagebreak, anchor in IE8 Fixed : ppt, xls files giving Inavlid Mimetype error on upload. Fixed : Use of source tags in video/audio if more than one source url. 2.3.2.2 Fixed : Error when importing profile. Fixed : Colorpicker colour not applied in Font Text Colour or Font Background Colour. 2.3.2.1 Fixed : Toolbar icons not showing when editor Compression options are activated. Fixed : Custom Character description. 2.3.2 Fixed : Error saving flash / iframe elements Fixed : Filesystem selection in parameters. Fixed : Remove filesize check when validating uploaded file (causes errors on some systems) Fixed : Menu links not returning sub-menus in Joomla 1.5 Fixed : Class stripping when pasting from Word etc. Fixed : Invalid File Type error when uploading htm/html files. Fixed : Remove version check for JCE MediaBox Popups causing blank page in link dialog in some instances. Fixed : Update powerpoint mimetype validation. Fixed : Use src attribute instead of nested element if single source in Fixed : Issues with MediaBox parameteres when editing popup. Fixed : Errors in Joomla 3 when using JParameter. Changed to JRegistry. Fixed : Strict Standards errors caused by backwards compatbility issues. Update : Codemirror, JQuery, JQuery UI Added : Dialog button icons due to JQuery UI improvements. Added : Footnote processing on Paste Fixed : List conversion on Paste Fixed : Keep in td elements. Fixed : Use utf-8 space if Encoding set to UTF-8 Fixed : Colorpicker now shows theme and custom colours. Update : Improve Help dialog layout with collapsible and draggable frames. Update : Improve Updates dialog layout Fixed : Handling of UNC paths on IIS systems. Added : Postgesql support (Joomla 3 only) Added : Editor and Plugin version numbers added to script / stylesheet URLs to prevent use of cached files from previous versions. Fixed : Styles removed from some elements when using backspace in Webkit browsers. Update : Updated input filtering. Changed : Process @import and googlefont rules for Font List using javascript instead of PHP. Fixed : Some Media Player options not applied in Media Manager. Fixed : Allow for empty usergroups in Editor Profiles if a User is set. Changed : Optimize png and gif files. Fixed : Add task=weblink.go to all J2.5 weblink items Fixed : Fix serialization of embed flash attributes Fixed : Link selector causing links to be inserted with an href of #mce_temp_url# Fixed : Allow for additional query data on media URLs Fixed : Image source of images uploaded using drag & drop on IIS servers. Fixed : Error message when attempting to update a table with a border value set. Fixed : Float style removed from image when adding a link to it in Webkit. Fixed : 404 error in Updates dialog when triggered from "Updates Available" link. Added : Option to set File Browser dialog width and height. Fixed : Cleanup after add-on update / install. Fixed : Extension install improvements. Fixed : Install errors in Joomla 1.5 due to incorrect temp folder path Added : Attempt to fix Profile saving when server is running suhosin extension. Added : Page loader in Profiles list and edit screens. Fixed : Gzip encoding check in script packer. 2.3.1 Fixed : Styles, Format etc. lists not translated if no language pack installed and Admin language is not english. Fixed : Editor doesn't load if a user is assigned to the Profile that is not in one of the selected User Groups. Fixed : Save and Save & Close buttons not availble in Preferences dialog in Joomla! 1.5 Fixed : Package and temp folder not removed after plugin install. Fixed : Various css fixes for the "Mission Control" admin template. Fixed : Editor would fail to load in K2 in some instances if an Extra Field was enabled. Описание: JCE Editor набор инструментов для CMS Joomla, предоставляющий возможность создавать и редактировать контент в соответствии с вашими требованиями. Просьба перекачать, обновил плагины.
Текущее время: 10-Июл 00:45
